What the hell is happening
Old Apr 19, 2019 | 02:13 AM
Nathan Staples's Avatar
Default What the hell is happening
I cant get the car in gear. I came out and started the car( 1999 disco 2). It wont go into gear, foots on the break yet it wont go into gear. If I turn off and turn on it will sometimes go into gear.what is happening now?
Old Apr 19, 2019 | 05:52 AM
NewToTheTwo's Avatar
A quick reference for you to read over - https://landroverforums.com/forum/di...to-gear-84947/
Old Apr 19, 2019 | 06:35 AM
mln01's Avatar
Brake light switch
If the brake light switch does not signal the BCU that the brake is applied, the shifter interlock solenoid under the shifter bezel does not operate to release the shifter from Park. You can remove the shifter bezel by pulling it straight up, and then manually retract the solenoid plunger to release the shifter.
The new style brake light switch is $11.95 at Auto Zone and is easy to change. The one I bought at Auto Zone in mid-2016 was in a Duralast box but was marked with the Land Rover logo, just like what you would get from a Land Rover dealer.
https://www.autozone.com/electrical-...eVehicle=false
Meldav32
Jul 12, 2024 06:10 PM
KeizerRover
Mar 6, 2016 05:50 AM
oljohnboy
Sep 23, 2014 02:34 PM
mellyagaunce
May 18, 2009 08:08 PM
cstocks
Jan 17, 2009 10:43 AM
