What is this...and how do I fix it?
Old Jul 6, 2013 | 09:42 PM
blackpaw80's Avatar
Default What is this...and how do I fix it?
I have been chasing a annoying noise since I bought this truck that sounds like a small gauge chain being dragged underneath the truck.
I found it today after checking the prop shaft rebuild. After the front end of the prop shaft meets the front differential, right behind the four bolts, there is a metal ring (pointed to by the arrow, that is completely loose.
Can someone please advise? Can I just punch it back into its home?
Old Jul 6, 2013 | 10:02 PM
blackpaw80's Avatar
From the Rave it looks like the Pinion Flange, on p.54-7.
I won't have time to look closely into it until Wednesday and I just purchased the truck so curious how severe a problem this is....
The seal behind it appears to be holding, unless it's completely dry.
Old Jul 6, 2013 | 10:10 PM
coors's Avatar
Im not sure why it would be loose. But I would suggest stop driving the truck, pull the prop shaft, and inspect the flange nut. If loose Tighten it down to RAVE spec (90ftlb??).
Squeeze some grease into the propshaft u-joints while you're under there.
Old Jul 7, 2013 | 12:15 AM
dr. mordo's Avatar
I agree
Old Jul 7, 2013 | 07:24 AM
blackpaw80's Avatar
Plenty of grease in the U-s, I just rebuilt the propshaft.
I've looked through the diff rebuild posts and can't find anything that elaborates on the flange.
My current plan is to drain the differental, and assuming its holding oil, I'll just secure the flange with the nut and call it good......I'm sure it will not be that simple...the manual does mention a special tool (LRT-51-003) to secure the flange while the nuts removed.
Old Jul 7, 2013 | 07:59 AM
Ghaniba's Avatar
My last offroader had the exact same issue - It's basically just a dust shield. Put it in as best you can and put a little ring of RTV around it and it'll shut it up. It's nothing critical at all - and yes, that jingling will drive you mad.
Dave
Edit: Put the RTV on the outside edge of it, as the inside edge spins. Just being overly clear.
Old Jul 7, 2013 | 09:04 AM
blackpaw80's Avatar
Dave....THANKS!!! I've been sitting here at work stressing over it.
Thanks to everyone else on this forum too, this is great!
lsmit605
May 11, 2011 11:50 AM
jnielsen78
Mar 9, 2011 12:29 AM
tsuami1
Jan 19, 2011 08:14 PM
LambChop
Dec 7, 2008 11:39 AM
Rich 00 DISCO
Sep 7, 2008 09:31 PM
