What to look for in a used 4.0- will bar replacing a 4.6
Old May 20, 2014 | 01:30 PM
cromartie's Avatar
Default What to look for in a used 4.0- will bar replacing a 4.6
My 4.6 is making a rAcket. So the engine will be replaced. To build with top hat liners will cost a lot, so was looking for another option.
Old May 20, 2014 | 02:32 PM
Dane!'s Avatar
Get a good GEMS 4.6 and call it a day.
Old May 20, 2014 | 07:28 PM
cromartie's Avatar
Default Where?
Heard they were hard to find. Let me know if you know where I find one. Also is it plug and play?
Old May 20, 2014 | 08:29 PM
04duxlr's Avatar
Nope. Not that simple. You need to make a few changes to the setup. Here's a writeup about going the opposite direction: Frankenrover - Swapping a Bosch D2 4.6 engine into a GEMS D1 Land Rover Discovery. Not sure how you are going to deal with the SAI thing.
Old May 20, 2014 | 08:34 PM
Dane!'s Avatar
You could use the block and rotating assembly for the 4.6 GEMS, then swap the rest on top of it. They have a better build quality than the D2 stuff.
Old May 21, 2014 | 07:07 AM
drowssap's Avatar
fine a good 4.0 boshe block and swap the rotating assembly with your boshe 4.6, must easier.
Old May 22, 2014 | 08:06 PM
cromartie's Avatar
would i need to do any machine work? or does it all fit? just looking for the least exspensive replacement option. Love the truck and would hate to have to part it out in order to replace the engine
Old May 22, 2014 | 08:10 PM
abran's Avatar
No machine work. the difference is the lobes/throw on the crank(Stroker crank), connecting rod length, and top profile of the piston.
The 4.0 and the 4.6 use the exact same block.
Old May 22, 2014 | 10:05 PM
RoverMasterTech's Avatar
You would need to re bore and oversize the Pistons, the Rings would try to jump over the ridge left by the lesser stroke.
Old May 23, 2014 | 06:25 AM
drowssap's Avatar
"You would need to re bore and oversize the Pistons, the Rings would try to jump over the ridge left by the lesser stroke" If you need to bore it and replace the piston then it wasnt a good block to begin with.
if you get a 4.0 block it would need to be honed and replace the rings and bearing.
