What are the most common faults
Old Jul 18, 2015 | 01:52 PM
Extinct's Avatar
I had one explode, took out all the hoses and shrouds. Went home and checked our other disco and found cracks in the fan - on its way out. Converted both to electric and have not looked back - much quieter, better fuel economy, cooler in traffic, no risk of exploding.
Old Jul 18, 2015 | 06:48 PM
OffroadFrance's Avatar
I don't know whether it's possible or even been tried but fitting the TD5 fan which seems more robust and I've never heard of any 'exploding' fatigue issues with it. I haven't a clue whether it would fit easily onto the Rover V8 engine.
Obviously electric fans are well tried and tested but they make me nervous in case the motor fails and leaves me stuck in the middle of nowhere. I suppose separate twin fans is the answer.
Old Jul 19, 2015 | 07:53 AM
mln01's Avatar
What? No mention of the Three Amigos? Or the throttle body heater gasket?
Also
- XYZ switch
- Brake light switch
- Door lock pin
Old Jul 20, 2015 | 06:35 AM
Extinct's Avatar
Also
- XYZ switch
- Door lock pin
Please elaborate on the XYZ and brake light switch, don't think I have heard those (and have not had to replace). Thought I mentioned door lock detent, should have mentioned pin as well.
Thanks ;-)
Old Jul 21, 2015 | 02:00 AM
Joe Btfsplik's Avatar
Default fans that self destruct...
[QUOTE=OffroadFrance;527488]I don't know whether it's possible or even been tried but fitting the TD5 fan which seems more robust and I've never heard of any 'exploding' fatigue issues with it. I haven't a clue whether it would fit easily onto the Rover V8 engine.
I was personally present in my friends D2 Td5 when the viscous coupling went - Boom. It damaged the rad, and was not cheap to repair. He replaced the fan while he was at it, but the repairs were not cheap.
Old Jul 21, 2015 | 05:24 PM
[QUOTE=Joe Btfsplik;527721]
Never heard of one in 13 years of ownership but if you're so sure don't fit one ..................... simples.
Old Aug 24, 2015 | 04:46 AM
muscarello's Avatar
This should be a sticky. Title it "Caveat Emptor".
Old Aug 24, 2015 | 08:54 AM
Thanks ;-)
The XYZ switch is the gear selector switch on the side of the autobox which suffers failure often and leads to the flashing M&S dash lights and limp home mode (third gear only) the switch is repairable by stripping and cleaning and replacing the alu rivets with M5 screws. This switch normally fails at circa 100k miles or so.
I've never had a problem with the brake light switch or the detents on the doors apart from replacing the door actuators due to electronic (fob) failure so it's difficult to comment.
Old Oct 24, 2015 | 03:42 PM
NVDiscovery's Avatar
I'm curious how you converted to the electric fan set up and what parts are needed.
Thank you.
Old Mar 10, 2016 | 10:14 AM
bradleyryanchidester@gmail.com's Avatar
Default Door and window seals
Anybody else have a serious problem with sealing air and or water out? When I get going over 30mph the air rushing in over the windows, (I'm pretty sure thats the culprit), is almost unbearably loud. I've adjusted the doors to close tighter, I'm afraid I may have to replace all of the seals, if I did that is there a better option than factory?
bullcrew
Jan 12, 2012 05:45 PM
Disco2001
Sep 2, 2011 05:26 PM
mgabriel
Mar 30, 2011 12:31 PM
hilltoppersx
ROAMING WITH FRIENDS
Dec 7, 2010 05:48 PM
lipadj46
Jun 12, 2009 12:04 PM
