What are the pros and cons to installing CDL on a 2003 Disco?
Old Nov 12, 2011 | 10:52 AM
aarongregor's Avatar
Okay cool, Thanks Mike.
Old Nov 12, 2011 | 11:10 AM
DiscoRover007's Avatar
Originally Posted by Kalel
I am going with ToddCo for my CDL and shifter.
I'm thinking about going ToddCo as well. They've got the front housing that an 03 t-case would need for $400 bucks. I believe the linkage comes with that as well.
Old Nov 12, 2011 | 01:25 PM
NiteTrain's Avatar
FYI I pulled a D1 shifter out of a junk yard for $35. This was before cash for clunkers so there are many more D1s sitting in junk yards now. check the PAP and local salvage yards in your area.
Pull-A-Part: Used Auto Parts For Less - Pull-A-Part
Old Nov 12, 2011 | 01:51 PM
What's the advantage of using a 2004 shifter vs. a shifter from a D1 or an early D2? I've got a 2003 DII.
Old Nov 12, 2011 | 05:42 PM
Linkage, be it D1 or 04 is extra.
Most D1 linkage can be bought for around $125 give or take, the 04 cable linkage can run $350 and up.
The D1 linkage is less expensive and pretty common to find, if not used a lot it does have a tendency to freeze up so you want to shift it once a month to keep everything moving. The 04, being a cable system is easier to install, shift and rarely if ever freezes up.
johnkbl
Jan 19, 2010 05:22 AM
tj
Mar 22, 2008 09:20 AM
prospective owner
Jan 14, 2008 08:04 AM
TRANSAFRICA109
Jan 8, 2008 05:46 PM
disco ii hse
Sep 3, 2007 10:50 AM
