What should I replace?
Old Mar 22, 2013 | 08:28 PM
bcball's Avatar
5th Gear
Default What should I replace?
I purchased a 2003 DII 2 years ago, it was in good condition at the time.
Things are now starting to wear out.
The watts bearing is gone in the rear suspension, and the front end is loose.
I plan on rebuilding it this summer, is there anything I should be really paying attention to? I was thinking of ball joints, wheel bearings, etc....
Should I use OEM parts or are aftermarket parts OK?
Any guidance greatly appreciated!
Old Mar 22, 2013 | 09:53 PM
dgi 07's Avatar
OK, where to start
What is loose in the front end, tie rods, ball joints, steering damper, steering box?
Have you crawled under there and taken a look to see whats not right?
Have you or do you know how to check a ball joint for play?
Wheel bearing? Do you have funky grinding or noise while driving?
OEm or aftermarket - Terrafirma does great steering linkage bars. and obviously, if you are doing a full bushing kit, aftermarket is way to go...
You got to give us a little more than you did.
elboy0712
Dec 19, 2010 02:48 PM
starcraft
Aug 11, 2009 12:16 PM
Roveroh
Feb 21, 2008 03:04 PM
Brad S1
May 9, 2007 10:18 AM
