What should I spary under the diff boot to un freeze it?
Old Mar 8, 2009 | 04:29 PM
VikingDiesel's Avatar
Default What should I spray under the diff boot to un freeze it?
I want to take the boot off and get the DIFF LOCK to work by spraying penetrating oil, is that really I need? WD-40 or somthin?
Old Mar 8, 2009 | 04:50 PM
It won't work. Depending on how frozen up the system is you usually have to remove the entire console to even get to the shifter assembly.
Old Mar 8, 2009 | 05:04 PM
its a TEXAS car so I dont think its that bad, theres nothing I can do if I were just to remove the boot and the spongy cover under the boot
Old Mar 8, 2009 | 05:10 PM
If you tried spraying past the boot, you would just get spray on the sheet metal floor of the tunnel.
Old Mar 8, 2009 | 05:16 PM
khuds308's Avatar
yeah your going to have to take that console out man.
Old Mar 8, 2009 | 05:25 PM
I got mine from under the truck.
DO NOT use WD-40, it will make it rust.
Use Liquid Wrench or the like.
If you spray it with carb cleaner first it will help to eat the corrosion.
Old Mar 8, 2009 | 05:28 PM
Getting under the truck and power scrubbing the linkage can sometimes free up th linkage but if it is a mix of dust moisture and lack of use, it may not free up then you go thru the floor.
Old Mar 8, 2009 | 05:29 PM
Once you do get it working use it once a month, even just sitting in the driveway and moving the gear shifter through all four gears will do the trick.
Old Mar 8, 2009 | 05:39 PM
Thanks for the info, is it more effective to take out the console or to go under the truck? Also, where under the truck exactly do I have to spray this? Any pics?
Old Mar 8, 2009 | 05:56 PM
Well, do you really want to rip out the center console if you dont have to? Sounds like a lot of work to me.
Run the front of the truck up onto your ramps, have your helper wiggle the CDL shifter while you lay on your back with your drop light and look for the thing that is wiggling.
Spray the **** out of it and wiggle some more.
Spray some more, back it off the ramps and try to move the CDL shifter.
It will be stiff, but just keep trying to move it, it will go.
If that doesnt work then go the other route, but why not start simple?
