What should I spary under the diff boot to un freeze it?
I want to take the boot off and get the DIFF LOCK to work by spraying penetrating oil, is that really I need? WD-40 or somthin?
Getting under the truck and power scrubbing the linkage can sometimes free up th linkage but if it is a mix of dust moisture and lack of use, it may not free up then you go thru the floor.
Run the front of the truck up onto your ramps, have your helper wiggle the CDL shifter while you lay on your back with your drop light and look for the thing that is wiggling.
Spray the **** out of it and wiggle some more.
Spray some more, back it off the ramps and try to move the CDL shifter.
It will be stiff, but just keep trying to move it, it will go.
If that doesnt work then go the other route, but why not start simple?
