What size D-Shackles needed for under a D2?
Like the title says, what size D-Shackles would you install under the D2 and how are they measured for size when you go to purchase them? I see where they could be installed on the rear undercarriage, can you add some to the front undercarriage? where?
Also, should this be something that is in an emergency kit to add when needed or would that be too late? So, should they be installed as basically permanent part of your D2?
bcolins
12-09-2013 01:14 PM
rezzrover
05-07-2013 06:02 PM
