What size mud terrains??
Old Sep 23, 2009 | 11:01 AM
98roverguy's Avatar
Originally Posted by kenk
That was pretty interesting. I think it also has alot to do with tire design and manufacturer, they all vary a little bit in size. I dont run full-blown mud tires, but my Cooper s-t's are fairly aggressive.
I could see where a M/T would rub in the rear with no trimming.
IMO, when I mounted up the 245/75, I did have to remove the front mud flaps off the factory running boards
Hey Kenk you wouldn't happen to have any pics would you? I've decided I will likely be going with the 245/75s after I do my OME job. Will also be removing the running boards and installing some good sliders, so the front mud flaps will go as well.
Old Sep 23, 2009 | 03:14 PM
mitsi88's Avatar
I fitted 245/75 MTs to my '97 - had to trim the rear wheel arch a bit to avoid rubbing on full articulation. They work a treat!
Old Sep 23, 2009 | 03:24 PM
kenk's Avatar
Yea, I can put some up, once I get home. Hard at work...lol
Old Sep 23, 2009 | 03:49 PM
kenk's Avatar
Originally Posted by oysterhead
why would i not put in a 3" OME instead of 2"?
if i didn't use the long travel shocks, the actual lift is more like 2.5", right?
that doesnt require an mods to brakes, etc.
so why not the 3" lift? what am i missing?
Nothing. I only wanted 2" of lift since I knew I was going with a 245/75 tire. 3" woulda been a little much,looks wise,with that size tire.
Paul Grant
May 9, 2012 06:53 PM
oysterhead
Oct 26, 2009 11:21 AM
salve7
Mar 23, 2009 12:44 AM
ek5usmc
Oct 15, 2008 01:16 PM
surfrover
Tires
Jun 2, 2006 09:26 PM
