What size are Sensor Ring Nylock nuts?
Just went through this a week ago........nuts are metric...6 x 1.0.
on mine...the studs screwed out on 3 or 4 of them and because of rust the sensor rings were VERY difficult to remove from the rotor. FYI if i ever do that job again I will buy new sensor rings and studs.........bad news is that you still have to get the old ones apart to save the hub assy! PB blaster and a BFH..........good luck
