What size are Sensor Ring Nylock nuts?
Old Apr 28, 2010 | 05:57 AM
WIS ROVER's Avatar
Default What size are Sensor Ring Nylock nuts?
Does anyone know what size and thread are the nuts for rear ABS sensor ring on a '98 Disco? I want to gather all the parts for new Rear Rotors before I get started.
Old Apr 28, 2010 | 09:28 AM
XCELLER8's Avatar
Just went through this a week ago........nuts are metric...6 x 1.0.
on mine...the studs screwed out on 3 or 4 of them and because of rust the sensor rings were VERY difficult to remove from the rotor. FYI if i ever do that job again I will buy new sensor rings and studs.........bad news is that you still have to get the old ones apart to save the hub assy! PB blaster and a BFH..........good luck
Old Apr 28, 2010 | 09:24 PM
WIS ROVER's Avatar
Thanks for the response. Geesh, I hope they come off OK.
The nuts that come up in a Disco brake search at Atlantic British are 3/8". I wonder what that's about?
Has anyone swapped out regular nuts with split washers (or some other locking washer) for the Nylocks?
Old Apr 29, 2010 | 07:57 AM
XCELLER8's Avatar
any way to lock the nut should be fine.....eventually RUST will take over anyway (lol)
Old Sep 17, 2010 | 09:00 PM
leadfoot's Avatar
How did you get them out??
dcarr1971
Feb 8, 2013 08:16 AM
jastutte
Dec 2, 2012 10:19 PM
innzane
Sep 23, 2012 01:43 AM
MARSRover
Jul 1, 2012 01:08 PM
Kalel
Mar 18, 2012 02:38 PM
