what is supposed to be in this spot?
Old Jan 16, 2009 | 08:26 PM
hag1128's Avatar
Default what is supposed to be in this spot?
I am going to try to do this without aq pic at first...............
2003 Disco SE java black and palomino
Can someone point me to the proper fir tree fastener that is used on the 'palomino' interior trim package I have a few missing in the cargo area trim.
http://www.roverparts.com/ProductLis...amp;PartNumber=
It looks like the light stone 3rd from top.
Now the tough one.
I have 2 rectangle openings locate in the hard plastic trim that is in the cargo area. It is the trim piece above the cargo side windows and below the curved upper roof windows. There is one on each side.
Hopefully someone can identify this as I am a poor picture taker.
Randy
Old Jan 16, 2009 | 08:37 PM
Rover Curious's Avatar
Default RE: what is supposed to be in this spot?
Optional alarm sensors? Not really sure on that one. I just went and looked at my '03 and I don't see anything on the plastic trim between the cargo windows and alpine windows.
Old Jan 16, 2009 | 09:06 PM
hag1128's Avatar
you can see the body underneath. There are two threaded holes like something is supposed to screw into it (seatbelts for se7 package). I will take a pic in the am.
Randy
Old Jan 16, 2009 | 10:05 PM
Disco2Guy's Avatar
Those two holes on the body you describe sound like they are for a dog guard install. I had to cut those holes in the trim of my truck to install the dog guard. The alarm sensors (for a D2 at least) are closer to the rear doors (maybe the B pillar?), the holes for the dog guard are about at the mid point of the rear windows. Where exactly are the holes?
Old Jan 16, 2009 | 10:25 PM
PEPE's Avatar
5th Gear
IF I MAY DISAGREE; THOSE RECTANGLE AREAS ARE FOR THE REAR PASSENGERS AUDIO OUTPUTS (HEADPHONES) IN A 7 SEATS DISCO. NOT AVAILABLE WITH THE NAVIGATION RADIO IN A 2004. HOPES IT HELPS.
Old Jan 17, 2009 | 09:42 AM
Disagree but turn off your Cap's.
Old Jan 17, 2009 | 10:21 AM
hag1128's Avatar
These are at the midpoint of the window.
I dont have SE7 - there is no electrical connections in these.
They were definately cut after the fact.
I seems too far back for the dog gate tho I woudl expect it closer to the back seats.. I will research this further as I may like that option for my dogs.
Randy
alpinab7
Nov 17, 2023 10:55 AM
jw928
Dec 3, 2008 10:43 AM
sayre05
Apr 2, 2008 10:12 PM
alpinab7
Aug 10, 2006 11:40 AM
Lebowski87
Jun 1, 2006 04:23 AM
