Wheel Changes
To add to what he said, the Disco 2's came from the factory with either 16 inch wheels or 18 inch wheels, and the tires on both were 29" tall. So no speedo changes are needed if you stick with stock size tires.
There is a guy on some of the forums that put toyota axles in his D2, and used a superlift box to adjust the speed signal sent to the computers.
Speedometer Correction - DiscoWeb Message Boards
There should be no issue as previously stated since 18's came from the factory as well as 16's. And since you are doing the opposite of what most other folks do, you should be able to get the 18" rims on a straight trade for your 16's. If I still had18's I would trade you in a second.
