wheel max load
Old Sep 10, 2009 | 08:23 AM
discoxd's Avatar
Default wheel max load
what does the max load on a wheel mean? is that how much weight each one can handle individually? so as long as the combined max load of four wheels is more than the total weight of the vehicle its ok? or do i have it completely wrong?
Old Sep 10, 2009 | 08:34 AM
Are you talking about the wheel or the tire? I have never seen anything stated about wheels before.
Old Sep 10, 2009 | 08:37 AM
discoxd's Avatar
i was just looking around at rims and found these... http://www.4wheelparts.com/Wheels/Se...n=PXA8089-6886
and it says the max load is 2200 lbs... so i was just wondering if i was thinking about it the right way...
Old Sep 10, 2009 | 08:41 AM
Yes, you are thinking in the right direction.
I wish I had information as to what our wheels will handle.
My concern is that yes, in theory, you could handle 8800 pounds but does that also mean is will take all the abuse from impacts, that we need for our Disco's?
Old Sep 10, 2009 | 12:13 PM
antichrist's Avatar
I can't lay my hands on the firgures I stashed, but the Wolf wheels are rated at 2200kg.
The alloys less than that, but can't remember the figures.
Old Sep 10, 2009 | 12:27 PM
discoxd's Avatar
kilos? so thats nearly 5000 lbs then?
i've got alloys on mine not steelies but i was just wondering if the rims in the link would just snap in half under the weight of the disco
Old Sep 10, 2009 | 01:31 PM
antichrist's Avatar
The ones you are looking at are per wheel, unless they use some whacko non-standard rating method.
As long as two of the wheels can support the full weight of your rig, you should be fine.
RYAN3326
Jan 25, 2013 02:11 PM
deploy
Sep 2, 2011 10:45 AM
muskatd
Jul 17, 2007 06:53 PM
angasreid
Oct 10, 2006 12:06 PM
pinoymoomoo
Sep 24, 2005 01:39 PM
