Wheel nuts - lugs...
Old Nov 7, 2025 | 08:58 AM
Externet's Avatar
Question Wheel nuts - lugs...
Hi.
Which other models - brands - years are interchangeable with Disco2s ? Are they unique to LR ? Inflated rust under the pretty clad layer giving trouble, want to visit a nearby boneyard for them.
Old Nov 7, 2025 | 09:40 AM
WaltNYC's Avatar
P38 rr 1995-2002
Old Nov 7, 2025 | 12:50 PM
PickleRick's Avatar
Your local auto parts store should be able to get you the dorman brand replacement nuts for about 4 bucks a pop. Unless you just like boneyard exploring.
Old Nov 7, 2025 | 06:41 PM
Externet's Avatar
Thank you, good information.
Part numbers found with your help are Dorman :
611-233.1 9-100006.1 611-233
Old Nov 7, 2025 | 06:42 PM
gecko951's Avatar
If you get the same lug nuts they are eventually going to have the same problem...you can put your current lug nuts in a vice and knock off the caps with hammer and punch or screwdriver....just make sure the correct size socket (26mm) goes into the tire change kit.
Externet
Oct 1, 2025 07:27 AM
SimAsh
May 8, 2023 04:53 PM
evan
Nov 27, 2007 07:14 AM
SpeedAgent
Aug 23, 2007 07:41 AM
LRDisco94
Feb 13, 2007 07:07 PM
