Wheel trim/arches
Old Sep 3, 2015 | 09:02 PM
abran's Avatar
I used Duplicolor brand bedliner. Gave them just the right amount of texture and is super forgiving when you paint with it. I got some clumps I didn't like and just dabbed them up with a paper towel and kept painting. I don't have any pics, I am going to do a front bumper this weekend. Its the best.
Old Sep 3, 2015 | 11:55 PM
chubbs878's Avatar
It is indeed a time-consuming mod to refurbish the wheel moulding but if you have time, you will save a fortune. Plus it is just as difficult to remove the originals then replace with expensive new set. I tried plasti dip but it didn't hold up well for me so last night I texture-rolled the wheel arches and rocker mouldins with Kevlar bed liner. It looks awesome and seems much more durable than the flimsy PlastDip coating. Make sure you scuff or sand the smooth finish and apply a good grease and wax remover if you plan on doing anything to the pieces otherwise, you will have a lot of problems with bubbles, peeling, runs, etc. do it right the first time because it will take 10 x times as long to remove new coatings, prep again especially if you are taping-off. But definitely make a move because the vehicle looks so much better when the outer mouldins don't look all raggedy
Old Sep 4, 2015 | 09:05 AM
cosmiccharlie's Avatar
Take them off and throw them in the trash bin! Looks better without them IMO.
Old Sep 4, 2015 | 05:48 PM
dgi 07's Avatar
YESSSSS....
LET THE REVOLT OF THE FLARE LESS BEGIN.
SHOW YOURSELF MY BROTHERS.....
Sorry. Been a long week
Old Sep 4, 2015 | 09:33 PM
Twix's Avatar
I'm afraid to see what's under my plastic. Probably the real colour of the truck. And that will make me want to paint it lol
Plasti-dip on the plastic is much cheaper
Old Sep 5, 2015 | 09:40 PM
ATLDisco's Avatar
I just got done plati-dipping mine. Looks great, easy to do, and if you overspray, (which you will) it takes all of 45 seconds to wipe off when it dries.
Did my front grill and bumper in plasti-dip as well. I'm sold on the stuff. When it screws up you just peel and re-spray.
Old Sep 6, 2015 | 01:55 PM
wynhd's Avatar
I had mine rhino lined, paid $100, did while on vehicle and it included the rear door latch to match. Never have to worry about again.
Old Sep 7, 2015 | 11:05 AM
mln01's Avatar
Cosmic, what did you use to remove the adhesive after you pulled off the wheel arch trim?
Old Sep 7, 2015 | 11:07 AM
mln01's Avatar
Originally Posted by cybercop
I took mine off carefully, sanded each down with 100 grit then with 300 grit.
Put some back textured 3m automotive spary, then 3 coats of black semi matt black paint.
Looks Great.
Highly unrecommended. What a pain in the ****!
And Cybercop, what adhesive did you use to reattach them?
Old Sep 8, 2015 | 12:32 AM
toofaroffroad's Avatar
To each his own, but I'm not sure why you would bother taking them off to paint them. I bought a can of $7.99 gravel-guard and some masking tape and just covered the area around the arches. That was 2 years ago and it still looks great.
These trucks also look great with the flares taken right off.
