When coming to a stop idle drops very low and sometimes truck stalls???
Old Jul 24, 2012 | 09:11 AM
So, clean it then get back to us.
Old Jul 24, 2012 | 09:45 PM
me 2's Avatar
Default stuff
Ok, so removed tb hose to valve cover and intake hose and tb is extremely clean. Drove truck for about 10 mins before it started doing the idle drop but after 20 or so mins never stalled but came very close. Noticed the slap or clank noise again when letting off the gas peddle. When coasting I can push the gas peddle and let go and get the clank sound somewhere by the tranny.
Do have the three amigos now. They kinda popped up once in a while but now the three lights are on constant.
Also have a q on the tranny fluid. When I removed the old motor alot of fluid came from the tranny so when the new motor was in and running I attempted to top off the tranny fluid but when the truck was on a flat service and removed the bolt to top it off fluid started coming out so I reinstalled the bolt and never refilled it. 1. How could the fluid be so overfilled in the tranny and 2. Was it trannt fluid that came from the tranny when I pulled the motor? (cause it was alot of fluid)
Sorry so long.
Old Jul 25, 2012 | 06:30 AM
Send me your number so I can walk you thru what to check.
Old Jul 26, 2012 | 01:03 PM
jfall's Avatar
If your cell phone can record, when the clank comes, hold the cell phone to the plastic or maybe even the top of the H/L shifter and try to capture the sound.
Maybe you can put it on youtube so we can hear it.
Old Jul 30, 2012 | 12:29 PM
me 2's Avatar
Default stuff
Hey Mike, havent had a chance to get back to you. Ill IM you.
I had to tighten up the tb a bit to keep it somewhat steady but can feel a big lag when getting off the gas still. Almost like the breaks are being applied a bit.
Old Dec 10, 2012 | 07:02 PM
micahneil's Avatar
5th Gear
I have the same problem but it does not die in neutral. It is worse in low range.
Old Dec 1, 2024 | 04:12 AM
mjzero's Avatar
Did this ever get figured out? My disco’s having the exact same issue as described from the idle and stalling to the sounds. Have several codes but they were there before the issue began.
oferl
Feb 11, 2020 11:43 AM
rolandroy
Nov 22, 2014 08:48 PM
jgeorge
May 19, 2012 06:24 AM
SurfRat
Jan 16, 2012 10:17 PM
