where to clear the 3 amigos?
id like to know where I can delete my 3 amigos so i can see what will cause them to re-appear again. I am doing the my front brakes since there is a big squeal coming from them which is messing up my wheel sensors hopefully causing my 3 amigos. I dont wanna go to the dealership obviously
The dealer will read but not clear the codes, find a small shop that has a scanner that can access the ABS and get them to do it. Fix the brake squeak first. If you throw a panic stop on a loose surface can you feel the ABS pulsate thru the brake pedal?
yea, for some reason I really dont feel that ABS pulsating actually but considering the ABS light is on to begin with, that means automatically the ABS wont work regardless since the light is on
cammyr01
Jan 5, 2015 02:42 AM
