where to clear the 3 amigos?
Old May 24, 2009 | 08:59 PM
VikingDiesel's Avatar
Default where to clear the 3 amigos?
id like to know where I can delete my 3 amigos so i can see what will cause them to re-appear again. I am doing the my front brakes since there is a big squeal coming from them which is messing up my wheel sensors hopefully causing my 3 amigos. I dont wanna go to the dealership obviously
Old May 24, 2009 | 09:03 PM
You either need a trip to the dealer or a indie shop with TestBook or T4 computer.
Old May 25, 2009 | 08:13 AM
The dealer will read but not clear the codes, find a small shop that has a scanner that can access the ABS and get them to do it. Fix the brake squeak first. If you throw a panic stop on a loose surface can you feel the ABS pulsate thru the brake pedal?
Old May 25, 2009 | 09:13 AM
yea, for some reason I really dont feel that ABS pulsating actually but considering the ABS light is on to begin with, that means automatically the ABS wont work regardless since the light is on
Old May 25, 2009 | 10:24 AM
NO, not the case. When the 3 Amigo's are on, the ABS will work as long as it is not the module that is failing, the Hill Decent and T? won't work usually.
cammyr01
Jan 5, 2015 02:42 AM
iplayblues4u@comcast.net
Jan 6, 2010 08:43 AM
VikingDiesel
Jun 10, 2009 09:06 AM
loic
Nov 4, 2007 07:13 PM
Darksidetone
Feb 9, 2007 09:15 PM
