Where do these 2 dang green wires go?
Old Jan 1, 2017 | 08:37 PM
Luckyjayb's Avatar
I didn't take pictures like I should have, as my wife said, typical guy. I thought it had to be close since they are close to the injector harness and coil pack connectors. Thanks for all the help guys
Old Jan 2, 2017 | 01:13 PM
johnkbl's Avatar
You can search in the Electrical troubleshooting manual for the colors of the wires... Each wire has a color code and you can search for it in the manual. There is also a connector section with pictures of the connectors.
Your wires are green but you need also to check if the wires have a secondary color to include it in the color code.
Old Jan 3, 2017 | 12:23 AM
kristoffersmith's Avatar
I remember rebuilding my buddies rover and they where bolted to the back of the heads somehow.
Old Jan 3, 2017 | 07:19 PM
Luckyjayb's Avatar
Well they were both solid green and appeared to be grounds. I saw what y'all were talking about in the Atlantic British video. I put them on top of the coil pack bracket since they appeared to be coming out of that part of the harness by the connectors for the coil packs.
Old Jan 4, 2017 | 03:41 PM
Charlie_V's Avatar
Same here. Top bolts of coil bracket. I have also used the bottom bolts at various times (simple because the loop in the wire helps me position them--have I mentioned, lately, that the location of our coils is an absurdity on the scale of sagging pants?!).
ljdiscovery
Jan 14, 2014 11:08 PM
bamaboy473
Jun 3, 2012 08:08 PM
ljdiscovery
Jul 31, 2009 03:14 PM
VikingDiesel
May 26, 2009 02:43 PM
johnnybob06
Jan 3, 2008 04:24 PM
