Where does this bolt go?
Old Feb 11, 2022 | 08:13 PM
Brandon318's Avatar
Default Where does this bolt go?
The machine shop removed the ground strap and bracket from the head and I want to check if you guys remember which holes they go in.
Also, there weren’t two bolts on the bottom of the engine hoist bracket, but should there be? Any idea what their torque spec is?
Old Feb 11, 2022 | 08:26 PM
Extinct's Avatar
Fork bracket is to hold the plug for the CPS, goes on the outer bolt hole. ground strap goes on the inner top hole. Intake bolt specs should do for the torque spec.
Old Feb 11, 2022 | 09:06 PM
Brandon318's Avatar
Awesome, thanks! Any idea whether that hoist mount is missing two bolts?
Old Feb 11, 2022 | 09:44 PM
Extinct's Avatar
Bolts go in top two holes from the factory, no bolts in lower holes.
Old Feb 11, 2022 | 09:46 PM
Brandon318's Avatar
OK and then last question - there's the one rouge bolt on the left-side head, top-right corner. Is that just an empty bolt? The machine shop probably removed it and then replaced it, but now that everything back there was touched, I don't trust my memory nor their ability to put things back where they removed them from.
Old Feb 11, 2022 | 10:35 PM
Extinct's Avatar
Ok, harness fork in lower left, ground strap in upper left, harness strap (connect to the harness) with extra bolt in upper right - all on left head at the rear. Lower right hole looking that rear is empty.
Old Feb 12, 2022 | 09:47 AM
Brandon318's Avatar
Many many thanks 🙏🏼
TimInNova
Nov 18, 2021 05:15 PM
adolfojbonilla
Jun 10, 2017 09:39 PM
DuoRover
Dec 4, 2016 07:23 PM
audiS4S6
May 6, 2010 06:17 AM
2001SE7
Mar 22, 2010 08:52 AM
