Where does the O ring go on PAS high pressure inlet
Old Jul 16, 2013 | 08:46 PM
sickdisco's Avatar
5th Gear
Default Where does the O ring go on PAS high pressure inlet
Does the O ring just go like 1/4" in on the fitting - on the outside of the little flange? Seems logical... also, once it's on there is there any trick for re-installing the fitting or do you just "push it in"
Old Jul 16, 2013 | 09:22 PM
borchera's Avatar
When we replaced ours the o-ring went on a recess portion of the inlet pipe. A word of caution, we found the inlet pipe was longer than the pipe we replaced and ended up cutting a small portion off the the new inlet pipe.
The new pipe would not seat pass the o-ring until we had remove a small amount from the tip of the new pipe.
Not sure why this was the case and we triple check the part numbers.
Another tip is if you live in a salting state to paint the pipe before installing to give some protection against the elements.
2003 Discovery with all high miles services complete w/ 139K
Old Jul 17, 2013 | 06:51 AM
antichrist's Avatar
The o-ring goes on the tube, on the side of the flange closest to the end.
Fast951
Sep 26, 2019 09:15 PM
allegedly
Jan 10, 2015 08:45 AM
BTamas
Aug 21, 2013 08:04 PM
demonlarry
Feb 27, 2013 10:11 PM
innzane
Sep 23, 2012 01:43 AM
