Where does this plug go?
Old Nov 24, 2008 | 12:52 PM
grussell's Avatar
Default Where does this plug go?
I recently purchased my 01 Disco II. This forum is great and I have had a few questions answered already. Here's my next one:
I was taking a very close look around under the hood as I am getting ready to replace the ignition wires based on feedback here.
I noticed this plug under the power sterring housing in a holder and from looking at the passenger side it looks like it goes to the brake sensor in the wheel. The left sensor has a wire that comes up and goes into the firewall. I removed the kick panel and traced the wire into the center dash. It goes under a metal bracket, so there is no way to get a plug under that bracket without removing some dash components. I can tell it has been replaced as it is clean and not covered with road grime.
I am scratching my head on this one. I have attached a picture of the plug.
[IMG]local://upfiles/12225/C91C943C83144157A08A516CEFDF8C72.jpg[/IMG]
Old Nov 24, 2008 | 01:27 PM
Urban Panzer's Avatar
Default RE: Where does this plug go?
Thats an ABS sensor wire. "originally" the repair to a faulty ABS sensor was to fix it from that plug down to the wheel sensor, how ever the "later" repair was that the new sensor came with a very long lead and was wired directly from the hub all the way into the car and up to the SLABS ECU.
So I would "assume" you car at some point in its life has had an ABS sensor fault and hasbeen fixed by the dealer using the "later" method.
TRIARII
Sep 1, 2012 03:39 PM
DiscoRover007
Jul 20, 2012 04:37 AM
maxman
Mar 30, 2011 11:56 PM
dynomite
Oct 12, 2010 09:25 PM
apcollin
Jan 4, 2008 08:54 PM
