Where does this wire go????
Old Jan 12, 2009 | 07:54 PM
tzrover's Avatar
8th Gear
Default Where does this wire go????
Hello all,
I was topping off some brake fluid in my disco when i noticed I wire with what looks like a yellow 3 prong plug on the end of it plugged into nothing. It is connected to the wire harness attached to the master cylinder resevior cap. I looks like lt should plug into somethig underneath the master cylinder. I have no idea and nothing jumped out at me as to where this might go. Any help would be great.
Thanks,
Todd
Old Jan 12, 2009 | 08:04 PM
NW_rockhound's Avatar
Default RE: Where does this wire go????
Why are you topping off your brake fluid? Do you have a leak? If there are not leaks in the system, I suggest a quick brake inspection. Chances are your pads are wearing down and need replaced soon. The fluid that WAS in your reservoir went some where.
Old Jan 12, 2009 | 08:26 PM
tzrover's Avatar
8th Gear
I think I do have a leak but it appears that it is coming directly from underneath the resevior. I have an master cylinder repair kit on order. In the mean time...... topping off the brake fluid. But this prong/plug is what I am wondering about
Old Jan 12, 2009 | 08:39 PM
There should be a harness for it to plug into right around there, it might be tucked up under something.
Old Jan 12, 2009 | 08:53 PM
tzrover's Avatar
8th Gear
ILL have to take a closer look around tomorrow and look for something that it might connect to. thanks for the replys
tcbinaflash
Nov 20, 2011 10:47 AM
s10lowrider1994
Sep 15, 2011 10:07 PM
sloppyjoe
Sep 12, 2009 06:16 PM
agarabaghi
Aug 19, 2005 09:03 PM
tbesselman
Jun 3, 2005 11:47 AM
