Where's that blasted relay
Old May 17, 2006 | 12:00 PM
shellgrip's Avatar
4th Gear
Default Where's that blasted relay
The Cruise Control on my 97 300TDi has been playing up for a while now. I've been through all the obvious stuff - the vacuum pipes (fine), the pump (fine), the brake switch (fine) and so on. The odd behaviour is that every now and then it'll work perfectly (hence good reason to believe the mechanical bits are OK) AND if I turn off the master switch before stopping the engine, it'll work again the next time I drive 90% of the time.
Given this, a learned colleague and I have decided that it's worth checking the relay that operates the pump - it seems entirely possible that this is unreliable but works when it does, if you see what I mean. However, we can't find the bloody thing. The crappy Haynes manual I have says it's behind the passenger footwell but I can't see it there - or at least none of the wire colours seem to match up.
Can anyone say for definite where the Cruise Control relay is located?
Jon
Old May 19, 2006 | 07:58 AM
shellgrip's Avatar
4th Gear
Default RE: Where's that blasted relay
Can no one help with this? We're off to Yorkshire tomorrow and I'd hoped to get the hammer out tonight.
Jon
Old May 19, 2006 | 10:05 AM
Landzu's Avatar
I hope that they find the problem.
Then you will be the expert on this.
I just wish I had a diesel Disco.
Good Luck Mike.
Old May 27, 2006 | 04:39 PM
duboff's Avatar
don't know if it is the same as mine. 96 disco. i check the books and for the relay behind the passenger(right side)kick cover below the dash. hope it helps. gotta love a rover. duboff
bleizit
Jun 24, 2020 04:03 AM
RicketyTick
Jun 24, 2014 06:58 PM
s10lowrider1994
Oct 6, 2011 01:22 AM
stealthn
May 23, 2005 01:20 PM
Yetielliott
Mar 31, 2005 01:41 PM
