Whining Noise from Engine. Unable to Isolate
Old Dec 1, 2016 | 01:47 PM
MaineDisco2's Avatar
Default Whining Noise from Engine. Unable to Isolate
Re: '03 Discovery 2
I had a minor implosion of my water pump resulting in some repairs preventative maintenance. I just got finished with replacement of most of the ancillaries in the front of the motor.
Components replaced:
- Water pump and gasket
- Front cover, oil pump and gasket
- Timing chain
- Radiator and hoses with complete system flush
- PAS Pump
- Serpentine belt
- Belt Tensioner Pulley
- Cooling Fan
- Sump gasket
After completion of project, engine sounded fine for a day then developed a loud whine consistent with engine speed. Initially sound seemed isolated to alternator.
Alternator was replaced as a precaution but whine continues. Idler Pulleys were not replaced but it does not sound like a squeaky pulley noise.
Sound does not seem to be coming from the AC compressor. A/C works fine and does not impact noise volume, speed or intensity. I still cannot isolate problem. Anyone have thoughts on where this might be coming from?
Thanks,
Old Dec 1, 2016 | 02:25 PM
zuke's Avatar
I usually have a 3 foot piece of metal with me when I am chasing down noises in the engine bay. Place one end at different spots then put your ear on the other end. Move it around to narrow down the source.
Dont get caught in moving parts.
Old Dec 1, 2016 | 03:42 PM
abran's Avatar
PAS pump not bled properly?
Old Dec 1, 2016 | 03:49 PM
mollusc's Avatar
Try squeezing some grease into the idler pulleys while the engine isn't running, taking care not to get it near the belt. If the whine changes in character after you start the engine, it's likely that the pulley(s) are the cause. No change doesn't mean that the pulley is NOT the cause, however.
Old Dec 1, 2016 | 04:00 PM
I will try the grease trick to see if it helps. I had intended to replace them but opted out due to cost of new ones.
Old Dec 1, 2016 | 04:02 PM
I'll try bleeding again. had not explored that option. Noise sounds higher in the motor but will double check this. Thanks.
Old Dec 1, 2016 | 04:03 PM
Good trick, will attempt. Also exceptional advice about not being dismembered!
Old Dec 1, 2016 | 04:55 PM
number9's Avatar
Good way to check alt, ac clutch and pulleys is to remove the belt and spin them by hand. If going bad you can normally feel or hear them with the hand spinning. If bearing not trashed you can grease the pulley bearing by first removing pulley, using a small pick to remove the bearing seals, using a needle fitting on your grease gun and reinstalling seals. Replacement sealed bearings for the idler pulleys are also available and easily replaced if you have the tools.
Old Dec 1, 2016 | 05:21 PM
Went through the bleeding process again. No change but thanks for the advice.
Old Dec 1, 2016 | 05:25 PM
Used the metal trick and i actually seem to be getting the loudest vibration and noise from the new Alternator I put in. I cant imagine there is an issue with it. I'm going to explore the idler pulleys as well.
Oh I forgot to mention I changed out the Tensioner as well. Could this noise be a result of added tension on the serpentine?
