White nylon tube that secures headlight to the metal adjuster is broken. How to fix?
Old Jun 12, 2016 | 05:51 PM
bcolins's Avatar
Default White nylon tube that secures headlight to the metal adjuster is broken. How to fix?
On my 99 D2. The upper outside headlight mount/attachment point is broken and the headlight keeps falling forward,....aiming itself about 20 feet ahead of the front bumper. It is a white plastic or nylon tube that the adjuster ball end fits into,......and the other end is T shaped with two small Philips head screws securing the tube and headlight adjuster.
Wondering if there is a replacement part available, or, if not,....in anyone has had this same problem and been able to fix it with screws/bolts/nuts etc,....or, bonding the adjuster ball into the white plastic tube.
Brian
Old Jun 12, 2016 | 06:02 PM
Best4x4's Avatar
Land Rover Discovery 1 1994 1999 Headlamp Head Light Clips Set of 6 STC3368 | eBay
Do you mean those??
Old Jun 13, 2016 | 09:22 AM
bcolins's Avatar
Yes,......exactly! Thanks!!
Old Jun 13, 2016 | 02:00 PM
Best4x4's Avatar
No problem!
Old Jun 13, 2016 | 05:14 PM
OffroadFrance's Avatar
There are lots available online from numerous LR parts vendors, they seem to be a common breakage problem.
Old Jun 13, 2016 | 06:05 PM
Best4x4's Avatar
Old age catches up to all plastics sooner or later.
The Vivster
Jan 29, 2016 01:17 PM
Jon Pitts
Jan 19, 2015 12:04 PM
BrandonS
Dec 17, 2012 09:55 PM
adambarry
Mar 30, 2010 08:17 AM
nynole
Feb 19, 2009 01:11 AM
