Which White Shepherd product should I used in my 03 D2 Transfer case?
Old Sep 19, 2015 | 07:51 AM
bcolins's Avatar
Default Which White Shepherd product should I used in my 03 D2 Transfer case?
I've had a bit of seapage from my Transfer case. I want to drain and refill and try the White Shepherd product. Which Product do I use (They have several).
Also, thinking that a NON Synthetic might be less likely to seep, but, it seems everyone recommends the synthetic. I had numerous engine oil leaks in a prior D2, and I noted on a receipt, that the oil had just been changed to full synthetic just prior to my buying it. I drained out the synthetic, refilled with organic motor oil and EVERY leak stopped!
On the reverse side of that,....On a BMW Shaft drive, when I drained the regular gear lube out and changed to synthetic the day before a long ride of about 1000 miles,......I had a bad leak the next day at the final drive seal, leaking gear lube onto the rear brake rotor and tire,......not a good thing on a motorcycle. In this case, changing back to NON synthetic gear lube, did NOT fix the leak. I rode it for 3 days with it constantly seeping,....and had to replace the seal. BTW,......I have had over 40 Shaft drive BMW motorcycles,....have never had another bike leak at the final drive seal.
Brian in Cedar Park
Old Sep 20, 2015 | 04:11 PM
bcolins's Avatar
Anyone?
Old Sep 20, 2015 | 06:25 PM
Best4x4's Avatar
Instead of 80/90w GL5 why don't you switch over to 85/140w and see if the leak stops.
Is it leaking from the flat inspection plate on the TC? While it's empty you can remove that cover, and reseal it with RTV.
Old Sep 20, 2015 | 08:17 PM
bcolins's Avatar
I did both those things about a year ago. Bought the proper Gear oil resistant RTV, cleaned everything up, re-sealed the flat plate, put it back together, then filled it with 85/140 synthetic. seemed ok for a few days,......then started dripping again. It eventually stopped dripping. I think because the lube level got below the leak point. When I took it apart last time,....not very much lube came out,....so I figured most of it had leaked out. I think that where I am again.
Old Oct 18, 2015 | 09:45 PM
bcolins's Avatar
Default Back to my original question,....Which White Shepherd product to use in transfer case
Anyone tried this? If so,...which WS product did you use,....and,....how did it work?
BC
Old Dec 23, 2015 | 06:03 AM
bcolins's Avatar
Still hoping I can get an answer on this
Old Dec 23, 2015 | 06:22 AM
drowssap's Avatar
I don't see it now that Blue Devil has bought them out, I thought i used a product for transfer cases that i used on my D2 years ago.
Lacking that i would go for the rear main seal product as it is made to swell seals.
Ive used the rear main on my classic, worked well.
Old Dec 23, 2015 | 12:01 PM
DiscoCam's Avatar
X2 on the rear main seal product. Worked on my D2.
Old Dec 23, 2015 | 12:53 PM
abran's Avatar
Default Also...
I can't remember which ones but some of the inspection plate bolt holes go all the way through to the fluid area. These bolts need to be wrapped in Teflon tape before securing.
CANAMDiscovery
Apr 28, 2012 08:47 PM
taylor15
Dec 24, 2011 09:45 AM
HelenaRover
Oct 30, 2010 07:27 PM
bantham1
Oct 20, 2010 08:41 AM
d.m.disco
Oct 27, 2008 11:58 AM
