White Smoke?
Old Feb 21, 2011 | 05:51 PM
MGibbs's Avatar
Default White Smoke?
My possessed 03' Discovery is acting up again. After quite a bit of work (O2 sensors, valve cover gasket, MFA sensor, filters, crank shaft sensor) I thought it was over. Its not. Now I have puffs of white smoke from my exhaust that smells like gas.
No temp spikes or coolant loss but I have two engine codes that pertain to a bad MFA sensor. Two separate issues or both caused by the MFA? Anyone?
Old Feb 21, 2011 | 08:33 PM
Whats a MFA sensor?
Old Feb 22, 2011 | 08:42 AM
MGibbs's Avatar
Oh sorry....Mass Flow Air Sensor.
Old Feb 22, 2011 | 08:44 AM
hilltoppersx's Avatar
how many miles on your rig? have you checked the oil for contamination? what are the codes you are getting? do you mean MAF sensor?
Old Feb 22, 2011 | 10:04 AM
MGibbs's Avatar
87,000 Miles on it. Dipstick looked good (no mustard) but I am a little overdue for an oil change. I just bought 10 quarts of Rotella 10W40 and plan to change it this weekend. This white smoke has got me though....I don't seem to be losing oil or coolant! ???
Old Feb 22, 2011 | 10:35 AM
MGibbs's Avatar
The two engine codes are 4th gear ratio and MFA Sensor....as I understand it the 4th gear ratio is also indicative of a bad MFA Sensor.
Old Feb 22, 2011 | 10:57 AM
mwindth's Avatar
Default Don't be cheap on the MAF...
MGibbs,
This is one part on our "magnificent beast of a truck" that you cannot be cheap with...you must buy the genuine Bosch MAF sensor. Do you remember what brand you installed?
Old Feb 22, 2011 | 02:29 PM
MGibbs's Avatar
Yes, unfortunately I know that now ! I just sprang for an expensive Bosch from Atlantic. I was just wondering if this (the Mass Flow Air) would cause the white exhaust? Thanks !
Old Feb 22, 2011 | 03:07 PM
what type of air filter are you running? paper or K&N style? does it smoke after the truck is warm? does it smell sweet?
Old Feb 22, 2011 | 06:37 PM
MGibbs's Avatar
Running a paper filter. The exhaust smells like gas...not sweet smelling coolant. Just finished changing the oil a few minutes ago and it was 5.75 qts drained. Doesnt seem to be losing much oil. Its been smoking while running...not a ton but enough to cause investigation. Thanks for any help...
