Who has a transfer case out of the truck?
HELP Who has a transfer case out of the truck?
Trying to figure out if I'm missing a bolt. There is a threaded hole on my box that I can't tell if something should be in or not. If anyone has one out or doesn't mind crawling under their truck please let me know
If the input seal got torn during the install (or if it was not replaced and was worn to the other LR's input shaft vs the other D2's input shaft) it would seep right down past that plug as it's sunk down a bit vs the rest of the TC casing.
The good thing is it doesn't look like a super major leak. If that was the case you'd have applied a nice undercoating to your D2 of 80/90w or 85/140w.
That "funky plug" that is leaking is your intermediate pin. Yours appears to be standing proud of the case when it shoudl be sub-flush, the sealing o-ring may have moved out of the case. I bought a truck once with a bad transfer case, the nut on the intermediate pin backed off, the pin backed out, the gears ate themselves. I would recommend checking the nut on the other side. The pin is not hollow, there is not plug missing from the center of the pin, that is just the lathe turning center indention.
These images may help
Nut on parking brake side.
