Why do Disco diffs go bad?
Old Feb 8, 2020 | 11:51 AM
Brandon318's Avatar
Default Why do Disco diffs go bad?
So, yes, the front differential died on my Disco, and it got me wondering why/how. It has 83,000 miles on it and the PO replaced the fluid 20,000 ago with high-quality schmoo. Seems way premature. What's the failure mode here?
Old Feb 8, 2020 | 12:23 PM
SundayFunday's Avatar
I was told traction control puts a beating on the 2 pin carrier design.
the nature of how the traction control is sending a pulsing drive transferred thru the ring/pinion wears.
i was even given a theoretical amount of traction control uses before the carrier would see its limit! (Aprox 100x)
now I’m sure there is plenty of first hand experience here to conflict that.. Off-road use and on. Mine had roughly 165k on them. And 40k of the last included some good off roading.
I did notice as I serviced my rear the front was in similar condition on its way out.
Old Feb 8, 2020 | 12:52 PM
redwhitekat's Avatar
I’ve been following this forum since 2012 and it’s almost never mentioned here about diffs going bad
Old Feb 8, 2020 | 01:14 PM
Best4x4's Avatar
I have never replaced a diff in a single LR I've owned.
Old Feb 8, 2020 | 01:24 PM
Richard Gallant's Avatar
@redwhitekat That is largely because they do go but usually with higher mileage. One of the issues is as alluded to by @SundayFunday is traction control but there is little more to it.
Used as intended by the designers traction control does not really load up the diff very much, the intended use is:
  • Slow speed
  • Low revs
  • Very light throttle increasing gradually
I had mine kick in when I had to use a bit of heavy throttle on a uphill off camber muddy corner, there was serious clunk in the diff as the tire got traction. It also put a big sticky in my head do not do that again.
If that type of usage is common your diff is going to fail sooner rather than later, go on to a forum where the the 4x4 guys are primarily mudders lots of killed diffs. All from way to much throttle when spinning them something catches it puts a lot pf stress on the internals.
Poor maintenance is another issue, but 20000 miles is long time for fluid changes in a diff for a truck used off road a lot. I do mine every 2nd year or about 6000 miles, but it is a second vehicle and I go through a lot of water.
Gear oil matters too heavy is bad as it too light it is a splash lubrication system so need to stay with in sort of an ideal band
Old Feb 8, 2020 | 04:33 PM
acg's Avatar
acg
This is from the Ashcroft site:
A standard 2 pin diff centre, as fitted to all Discoveries, Defender 90's and Defender 110/130 front diffs can be a weak point in the drive train as the single cross pin can either friction weld to one of the planet gears which then spins and wears the casing hole or they can just shear, either way the 2 pin stock diff will not take much off road abuse before failing. They also wear prematurely if the traction control is used excessively ie in sand etc.
https://www.ashcroft-transmissions.c...ff-centre.html
My rear diff went out last year when off-roading. I replaced it with this Ashcroft 4-pin rebuilt diff.
I hear the 4-pin reverse-cut gears for the front diff is the way to go for reliability.
Old Feb 8, 2020 | 07:07 PM
Brandon318's Avatar
bbbvvbbbbbvvbbbbbbb
Interesting. Honestly, I have very little experience with differentials aside from changing fluid. I've never cracked one open to dissect it. That being said, now that I'll have one that's basically garbage, maybe I'll try rebuilding it or something for fun with one of those 4-pin arrangements.
I found a super nice used one on eBay from a dead Disco for $100.
Old Feb 9, 2020 | 05:36 PM
humroot's Avatar
Do you have a diff lock for the transfer case? Driving on dry pavement with lock on will do a number on the diffs when turning. Maybe the PO did this?
I've heard about a few rear diffs blowing out when off roading due to the points already mentioned, but rarely hear about the fronts.
Old Feb 10, 2020 | 09:00 AM
Alex_M's Avatar
The fronts in particular are also much weaker because they did not do a reverse cut ring and pinion; they used the exact same ring and pinion as the rear. That means you're putting all your power onto the coasting side of the gears making for a weaker differential.
Old Feb 16, 2020 | 10:01 AM
acg's Avatar
acg
On the subject of 4-pin and diff pegging, here is the best video on the subject:
Opportune discussion since my front diff is on the way out.
rit1267
Apr 12, 2015 07:16 PM
davidrover
Sep 3, 2013 05:35 AM
pauldavidanthony
Mar 31, 2013 04:15 PM
coldstart
Feb 28, 2013 07:56 PM
jmang
Oct 17, 2006 06:58 PM
