why does my power outlet fuse keep blowing
Old Feb 17, 2018 | 11:24 PM
09dewaed's Avatar
Default why does my power outlet fuse keep blowing
The power outlet shares the same fuse as the heated seats. Right off the bat that makes me skeptical. The 20 amp fuse has blown twice in the last 2 weeks. I'm guessing its when I have both seat heaters going and also have my phone charging in the front outlet. But why put them on the same fuse if all 3 can't operate at the same time??
I believe its th 20amp f15 under the steering column
Old Feb 18, 2018 | 07:49 AM
coors's Avatar
Sounds like there’s a ground fault. Potentially, in one of the heating (driver / passenger) elements or the power outlet receptacle.
Check for any foreign metallic (a dime?) items lodged in the power outlet receptacle. If it’s free of foreign metallic bodies investigate the source circuit from the terminals on the rear of the power outlet back to fuse block.
For the heating elements remove the power source from each seat, one at a time to see if you can isolate the faulty circuit. The seats may be wired inclusively not exclusively. Which means if drivers side is faulty, and the fuse opens it will de-energize the passenger side, vice versa.
gillart
Jan 7, 2015 07:12 PM
fishEH
Jan 5, 2014 10:36 AM
mbeasom
Apr 26, 2011 10:35 AM
Phototone
Audio/Visual Electronics
Apr 16, 2008 01:11 AM
mathis_m1a1
Jan 9, 2007 05:11 PM
