Why are engines fail
Old Aug 10, 2018 | 12:41 PM
  #31
Sixpack577's Avatar
Originally Posted by Dave03S
I'm no expert but i believe overheating is what usually causes slipped liners to whatever extent it actually happens in the real world.
Neither am I, but apparently the sleeves slip once it warms up to normal operarting temps. Maybe it takes one overheat to break them loose, I don't know.
I thought mine had a slipped sleeve, given it's loud rpm matching tapping after warm up. But, all bearings were worn out, the block deck showed no clean line between the sleeve and block. They were still blended from the original milling after sleeve install. The head gaskets had no impressions on the bottom either.
Regardless, my Dad and I pinned all 8!
The engine was already out, making it very simple.
I glued the bolts in with loc-tite, and safety wired each bolt to the block.
They will never slip now.
Old Aug 10, 2018 | 04:33 PM
  #32
Best4x4's Avatar
Overheating it once you’ll be okay, overheat it a few times & yep sleeves will probably slip.
Old Aug 10, 2018 | 04:45 PM
  #33
99FLDISCOII's Avatar
Banned
Originally Posted by Sixpack577
It IS true, and there's your answer.
Why is everyone not doing it? Apparently everyone can't do it, hence your asking for someone to do yours.
I've done mine, and it was easy.
As said, if there is no coolant leaking between the block and sleeve(which requires a tophat sleeve with o-ring to stop the leak), then pinning them prevents the movement and the loud tapping that comes with it.
Slipped sleeves isn't what kills these engines either, it is overheating them that does.
How do you find someone to work on it and what is the cost?
This happened after I put big tires on the car. So I don't know why it would be overheating enough tick just because of bigger tires.
Old Aug 10, 2018 | 05:33 PM
  #34
Sixpack577's Avatar
There are so many things that can tick in these engines, it's not nesacerily a slipped sleeve.
Sorry, I don't know who in your area can work on it.
And, bigger tires are heavier. They make the engine work harder. They can cause engine and transmission temperatures to rise.
Old Aug 10, 2018 | 06:08 PM
  #35
Dave03S's Avatar
As above increasing the load leads to weak parts of the system failing sooner... But it's a Rover and could have more than one unrelated problem at the same time.
Old Aug 11, 2018 | 12:42 PM
  #36
No Doubt's Avatar
If this were true everyone would be doing it to prevent a slip ticking and eventual engine self destruction. The cars would be going 300k+
If there is a way I can pay someone to do this please let me know and I will do it ASAP.
Click on TurboDave's link for photographs because they will make it clear in your head how easy this improvement can be: http://www.landroverresource.com/doc...g_V8_Liner.pdf
Now, since this is the internet and everyone likes to be argumentative, you're liable to say "Hey, he pinned those liners with the motor *out* of his Disco 2."
...and you'd be correct on that point, but missing the fact that you can drain the oil and drop the oil pan to achieve the same end result from below... with the motor still in your Disco 2.
You can also pull off the heads and achieve the same end results from above... with the motor still in your Disco 2.
Note that the job doesn't take much time. Note that the parts costs are trivial.
Also, you can "pin" all of your cylinder sleeves by replacing your cheap rubber head gaskets with real all-metal Cometic head gaskets to achieve the same result: https://landroverforums.com/forum/di...19/#post386380
Head gasket jobs are easily done with your motor still in your Disco 2.
Old Aug 12, 2018 | 10:14 AM
  #37
shanechevelle's Avatar
The tick is highly overrated.
if you've lost a cylinder, find coolant in your oil, steam cleaned effect etc then you might have liner movement.
however, if you havent cleaned the internals of shellac that builds up then that tick can be anything.
Old Aug 13, 2018 | 07:31 AM
  #38
Add to that cam bearings seem to be coming into play more frequently as they are found walking out of the journals
earlyrover
Jan 16, 2020 09:40 PM
redwhitekat
Nov 15, 2019 05:33 PM
Sixpack577
Dec 30, 2018 01:40 PM
Mpower1031
Mar 21, 2016 08:24 PM
cobbcj7
Nov 16, 2011 05:55 PM
