wierd rpm issue .... gun in mouth .. pull trigger ..
Old 01-18-2010, 02:27 PM
imarockstar's Avatar
Default wierd rpm issue .... gun in mouth .. pull trigger ..(updated with codes)
ok i have a 2003 disco hse .. ( not one of the ****ed up ones with a bad block).
couple weeks ago when it was super cold, my battery went dead. no biggy.
then last week i noticed when i went around corners, the engine seemed to stall for a half second or less. not sure how to explain if ... like if you hummed the letters :
hmmmmmmmmmmm mmmmmmmmmmmmmmmm
and the skip would be where the missing m's are. It also would not shift to 3rd gear until the engine got a little warm, that was weird. I figured it as because it was cold. It was like 15 degrees, and it never gets that low in Dallas, so i figured maybe my disco was confused lol.
Then last weekend I changed the breaks (nothing to do with this issue) .. on the way home my CHECK ENGINE LIGHT came on, and my rpms went weeeeeeeeeeeee .. like up to 5000 rpm then down to normal for my speed .. and then back up a couple ore times.
I think the car lost a little power also. Not sure. It started doing that stalling for a half second while i was driving ... then i parked it ... and I will take it to auto zone this next weekend so get the codes ...
if anyone knows of an issue off the top of your head and can point me in the right direction .. that be rad ... with that and then the codes .. i should know where to start ..
i will post the codes this weekend ..
thanks
bobby
Old 01-18-2010, 03:43 PM
LANDZUII's Avatar
When you get the codes let everyone know.
If you need a good place to work on it North Texas Rovers at 11324 Mathis Ave Dallas TX 75229 ph #972-869-4881.
Good people and they not only work on them they Own them.
The Owner has A NAS D110 and there are a few D90 for sale a round his place.
Old 01-18-2010, 03:57 PM
Default thanks
awesome ... I will post the codes .. and give that guy a call !!!
Old 01-24-2010, 01:11 PM
Default ok i got the codes .
here are the codes I got from the autozone ..
what do you guys think ..
P0130
P0171
Old 01-24-2010, 02:10 PM
NW_rockhound's Avatar
Not sure what the codes are for, but someone will decifer what those mean pretty quickly here......
In the mean time, I would check the transmission fluid level with the vehicle/fluid warmed up and running while checking. Some of your symptoms sound like they could be related to the transmission fluid level.
Good luck, David
Old 01-24-2010, 04:40 PM
RedCliffsRover's Avatar
6th Gear
I believe those codes have to do with the MAF and O2 sensors. The MAF my be starting to fail...Make sure you replace it with a quality OE replacement. If you buy a cheap one, you'll have to replace it again within the year.
As for the O2 sensors, It just recently replaced all 4 of mine...here's the info...
autopartswarehouse.com
Oxygen Sensors:
Front - Bosch #W0133-1610443 (15630) $64.95 each (2 required)
Rear - Bosch #W0133-1613716 (15175) $53.95 each (2 required)
Old 02-22-2010, 12:17 PM
G4AKumar's Avatar
I have the similar code, did your "service engine soon" light go off (after you had the O2-sensors installed and cleared the codes?) Please advice, and how long did it take you to complete the procedure? Cheers
AJ
Old 02-22-2010, 12:19 PM
G4AKumar's Avatar
Exclamation
P0130
P0171
I don't have any RPM issues, although, my paranoia does lead me to feel the truck is idling (or shaking a bit)-- maybe I'm over thinking this. But having said that, I do feel it's my O2-sensors (I have 95k on my 2004-- should I explain it?)
wamou
02-02-2013 01:44 PM
SDinDS
09-04-2010 09:07 PM
Jeff g
07-15-2010 06:51 PM
discoboy
02-15-2009 04:17 PM
LambChop
10-07-2008 11:57 PM
Quick Reply: wierd rpm issue .... gun in mouth .. pull trigger ..
