Wife's Disco Died, need help
Old Oct 28, 2016 | 07:05 PM
jskrebs's Avatar
Default Wife's Disco Died, need help
My wife drives a 2003 Disco with 80K miles. Its the base model and in very good shape.
Every so often we get the 3 amigos, a restart usually clears them.
Occasionally we get a CEL. I have a wifi ELM and read them with my I phone. I believe they were misfire related, but I cant recall the exact codes.
A week or so ago she was going shopping and pulled in to get gas. When she went to restart the car which would barley run, had no power and would not rev up at all.
She nursed it to a Garage 1 block away and got a ride home, I was out of town.
The mechanic at the garage initially thought it was a bad fuel pump and swapped it out. No joy
He said he could keep it running but the cat's heated way up.
He pulled some codes and said he got several misfire codes and an MAF code,
He tried a MAF next again, Nothing.
I stopped by today and we tried to start it, the truck would barely run
Thought I would start a thread here for some assistance.
Jeff
Old Oct 29, 2016 | 09:07 AM
jskrebs's Avatar
Buhler....
Old Oct 29, 2016 | 09:47 AM
Frank4's Avatar
Welcome to the forum. If you could post exactly what codes you are throwing we can start there. We will get you up and running. Don't let your mechanic throw anymore parts at it.
Old Oct 29, 2016 | 10:07 AM
jskrebs's Avatar
Thanks Frank4,
May not get them till Monday.
I have been on the forum for a while. had a 99 D2, Now the 03, and this is the first issue that stumped us.
Jeff
Old Oct 29, 2016 | 10:15 AM
abran's Avatar
I'm curious, how does your mechanic justify the parts he has installed which did not fix your problem?
It seems weird to me that you take your vehicle to a mechanic because they are professionals, yet they can't diagnose your vehicle without wasting your money.
There should be some recourse.
Old Oct 29, 2016 | 03:04 PM
jskrebs's Avatar
I think he returned the fuel pump and MAF sensor.....
The truck stopped working at the gas station where the mechanic is.
If it was home, a different story.
I was 200 Miles out so my wife made the decision to leave it there.
Old Oct 30, 2016 | 07:06 PM
jfall's Avatar
There is a fuel filter under the right part of the frame on a D1. D2 ? but change the fuel filter.
Might be the Crank position sensor acting up. But that only acts up usually when the engine is hot.
If the cats are heating up yes then excess fuel. Maybe one of the coil packs is going out.
You may want to put on an OBDII with live readout and see what is going on.
Also make sure the TEMP sender is sending the correct temperature to the engine computer. This is a separate sensor than the temp gauge.
Pretty much the inputs to the ECU computer are
Throttle Position
O2 sensors
MAF readings
Crank position
Temperature from Engine coolant
Temp from ambient air
All this has to line up.
Might be the throttle position sensor too.
But you should get codes for these.
Actually, this may sound stupid - but you may have a low voltage problem.
Replace the battery.
Old Oct 30, 2016 | 09:04 PM
abran's Avatar
cool, I thought you were on the hook for that.
Old Oct 31, 2016 | 10:53 AM
jskrebs's Avatar
Stopped by to visit the beached D2
Here are the ECU codes
P0102 Mass Air
P1300 Misfire detected
P304 Cylinder 4 misfire
P0302 Cylinder 2 misfire
P1668 no info
P1884 no info
The mechanic is waiting on me for a next step...
Old Oct 31, 2016 | 12:17 PM
mollusc's Avatar
P1668 is an immobilisation code. That could well be the source of one of your problems.
Read post #11 on this thread: Fault Code P1668 - Land Rover Forums : Land Rover and Range Rover Forum
The misfires are tricky. Lots of possible reasons for them.
