Will 97 burshguard fit 02???
Just for the looks. I think they look aggressive. Personal preference. I measured the frame on the 97 where it mounted to and it was same length as mine. Looks like all that needs to be changed is I need to cut slots into bumper for the guard to slide in to meet the frame mounts. Any thoughts?
Ok. So I took the bumper off today. Cut some slots for the brush guard to slide through. No perfect fit yet. I will need to cut the bumper cover where the crush cans lay behind because the bar lays against the bumper cover not allowing the braket holes to line up. i stopped because i didnt have to blades for my saw zaw to cut through the bumper reinforcement. I think when I can cut through that and take 45 degrees off crush cans I can cut away at the cover so the bar can lay in the cover. Any suggestions, thoughts???
Well... With alot of fabrication with the dremel and the saw zaw. I finally got it to fit without trimming the bumper in half. Went to off raod shop just to see how much they would charge to do it. over 300 bucks! I will post some more pics of the install and cutting processes as well as better pics of rover in the day time. Thanks for everyones help!
englishboyonice
03-11-2005 01:13 PM
nick1996rover
03-08-2005 10:25 PM
