2000 Disco II - Purge Valve - P0445
Old Nov 1, 2009 | 06:30 PM
smlrover's Avatar
4th Gear
Default 2000 Disco II - Purge Valve - P0445
I recently had the MIL light activate with a DTC P0445. I have researched RAVE and found that this is - Purge valve short circuit to ground
I measured voltage while cold - both sides of the harness read 0 V.
I cleared codes, waited until the vehicle came up to temp and the DTC was triggered.
I unplugged the harness and read the voltage. One side was at 13.6 V and the other (I am assuming the ground) at 6.4 V. I am assuming that this is not normal or is it?
When I unplugged the harness a P0444 was trigger, which I think should be normal.
I am trying to figure out whether I have a bad purge valve or an electrical issue. No fuses are blowing either.
Is there something else I should be checking. I have also looked at all of the hoses (at least the visible ones) and I do not see any cracks or hear any hissing.
Any help is appreciated.
Old Feb 8, 2012 | 09:09 AM
hilltoppersx's Avatar
did you ever get this solved?
Old Feb 8, 2012 | 09:19 AM
A little late on the question.
Old Feb 8, 2012 | 09:35 AM
better late than never. it comes up in a google search so might as well close the thread
Old Feb 9, 2012 | 11:10 PM
rimasco's Avatar
LOL!! I just had the 445 code.. I changed the gas cap and it came back.. and along with it the Purge Valve was clicking "unusually loud"..replaced the purge valve with a used one that a friend gave me..no more "loud clicking" and no code yet (fingers crossed)
Old Feb 10, 2012 | 05:38 AM
Awesome! Let us know if it comes back.
austinlandroverbill
Apr 1, 2015 06:26 PM
masism
Jan 26, 2010 07:07 PM
two45triox
Sep 23, 2008 10:23 AM
rsr50
May 6, 2008 10:55 PM
BuckMontecristo
Jul 27, 2006 10:19 AM
