Will 97 burshguard fit 02???
Old Feb 6, 2012 | 06:49 PM
Creed0330's Avatar
Default Will 97 burshguard fit 02???
Found 97 disco to part out, brushguard for 50 bucks, almost flawless. I have an 02 disco... Will it fit? If not how hard is it to make it happen? PLease help. Thanks.
Old Feb 6, 2012 | 09:15 PM
Yes it will fit with modification, there is a thread on it with pics.
Old Feb 6, 2012 | 10:11 PM
Creed0330's Avatar
New to forum. Any way you could point me in right direction? Also, do you know if this mod requires alot of cutting? BTW. Thanks!
Old Feb 7, 2012 | 09:43 AM
First, why are you wanting it, for protection or looks, cause they offer little or no protection.
People have cut and trimmed to install one on an early model D2, so ye will will require a little modification.
Old Feb 7, 2012 | 07:15 PM
Creed0330's Avatar
Just for the looks. I think they look aggressive. Personal preference. I measured the frame on the 97 where it mounted to and it was same length as mine. Looks like all that needs to be changed is I need to cut slots into bumper for the guard to slide in to meet the frame mounts. Any thoughts?
Old Feb 7, 2012 | 07:27 PM
https://landroverforums.com/forum/di...isco-ii-46461/
Old Feb 7, 2012 | 08:58 PM
Creed0330's Avatar
Thanks Spike. Ill give it whirl, and provide updates and pics. Probably will start on it in 2 weeks.
Old Feb 8, 2012 | 09:23 PM
Creed0330's Avatar
Ok. So I took the bumper off today. Cut some slots for the brush guard to slide through. No perfect fit yet. I will need to cut the bumper cover where the crush cans lay behind because the bar lays against the bumper cover not allowing the braket holes to line up. i stopped because i didnt have to blades for my saw zaw to cut through the bumper reinforcement. I think when I can cut through that and take 45 degrees off crush cans I can cut away at the cover so the bar can lay in the cover. Any suggestions, thoughts???
Old Feb 9, 2012 | 11:02 PM
Creed0330's Avatar
Well... With alot of fabrication with the dremel and the saw zaw. I finally got it to fit without trimming the bumper in half. Went to off raod shop just to see how much they would charge to do it. over 300 bucks! I will post some more pics of the install and cutting processes as well as better pics of rover in the day time. Thanks for everyones help!
FloppyRunner
Sep 21, 2005 03:03 AM
Mee
Sep 18, 2005 09:52 PM
englishboyonice
Mar 28, 2005 08:41 PM
englishboyonice
Mar 11, 2005 01:13 PM
nick1996rover
Mar 8, 2005 10:25 PM
