will not shift into 4 low
Old 05-13-2008, 01:11 AM
NiteTrain's Avatar
Default RE: will not shift into 4 low
I was stopped in netural at first but then let it roll foward a bit..btw do discos have chain or gear driven transfer cases?
Old 05-13-2008, 09:17 PM
roverguy7's Avatar
all gears... but yeah, it sounds like its the shifter solenoid, or maybe even just the input to it, see if the car starts in nuetral, if so, its probably the solenoid
Old 05-14-2008, 09:38 AM
There is alot to be said regarding the solenoid, if it is bad, you can't shift past neutral to low.
Old 05-14-2008, 08:43 PM
roverguy7's Avatar
not 100% here, but i dont think itll let you shift out of high without the solenoid working... can you shift out of high in drive?
windriver
03-28-2017 07:31 AM
gmad
05-09-2015 11:25 AM
Ringo
07-26-2011 11:59 AM
discotx
12-22-2007 10:08 AM
Quick Reply: will not shift into 4 low
