will not shift into 4 low
Old May 13, 2008 | 01:11 AM
NiteTrain's Avatar
Default RE: will not shift into 4 low
I was stopped in netural at first but then let it roll foward a bit..btw do discos have chain or gear driven transfer cases?
Old May 13, 2008 | 09:17 PM
roverguy7's Avatar
all gears... but yeah, it sounds like its the shifter solenoid, or maybe even just the input to it, see if the car starts in nuetral, if so, its probably the solenoid
Old May 14, 2008 | 09:38 AM
There is alot to be said regarding the solenoid, if it is bad, you can't shift past neutral to low.
Old May 14, 2008 | 08:43 PM
roverguy7's Avatar
not 100% here, but i dont think itll let you shift out of high without the solenoid working... can you shift out of high in drive?
windriver
Mar 28, 2017 07:31 AM
gmad
May 9, 2015 11:25 AM
importdave
Sep 25, 2014 10:18 PM
Ringo
Jul 26, 2011 11:59 AM
discotx
Dec 22, 2007 10:08 AM
