Will not start
How much gas in the tank? I had a failing fuel pump. Would run great full. And stall/crank a ton before starting,not start etc when under half.
New pump starts right up. Run great
Checking fuel pressure was a pain but will show if that's a possible issue.
Is the starter working? I ask as I had a problem when the thin wire to the starter fell off and it seemed to have a flat battery, the AA man tried to jump start it but no luck so recovered it home, next day the wire had come off
There is relay under the hood on of the yellow ones, the are all the same Check fuse 23 and swap relay 1 and 3 - I believe the the one for the headlights washers. That will at least confirm the relay and fuse are good.
fuse box
Then check all of your ignition fuses and relays there a lot of them
fuse box
