Will not start - help!
I just drove into the driveway (at my parents) and parked, and now my 2003 Discovery will not start. Everything appears to be fine otherwise, when the key is turned there is no solenoid click at all or any kind of evidence other than the intermittant power cut-off that is normal when starting. Can anyone help? I *NEED* to get this working in the next very short period of time.
RE: Will not start - help!
Problem with those aftermarket alarms is most of the time the technician leaves the factory alarm in also meaning when you have this problem, you NEED the old (factory) alarm pad to deactivate it, this is (in my guess, and having an aftermarket alarm put on also) hat has happened. If you do not have the factory alarm pad to deactivate the factory alarm... good luck.
If you had the aftermarket alarm put in at bestbuy, circuitcity etc... they most likely did not remove the old alarm and it is the one that has activated the ignition kill and prevented your vehicle from starting. So if you have the old alarm pad, try deactivating it. If you don't.... your kinda up a creek...
on
ORIGINAL: ajh
Locking with the key then unlocking reset the alarm. Looks like some kind of ignition disable got triggered. Anyone know how to disable this, I plan on adding a viper starter/alarm combo.
Mike
Evan5291
07-26-2011 06:06 AM
MattV8i
06-28-2007 07:24 PM
