Will this spare tire center cap fit a DII?
Old Nov 17, 2009 | 07:52 PM
RoverLover21's Avatar
Default Will this spare tire center cap fit a DII?
or were these specifically for DI's?
Old Nov 17, 2009 | 08:57 PM
Bueller?
Old Nov 18, 2009 | 08:50 AM
Rover Chris's Avatar
I would think if the lug patterns are the same it should "fit" but unless I am mistaken the D2 has bigger wheels I believe they went from 16" on the D1 to 17" on the D2. so it may be too small in diameter to cover the hole wheel and look a bit funny.
I cant say this for sure just my thoughts.
Old Nov 18, 2009 | 08:59 AM
looks like I was wrong about the larger wheels on the D2 the 18 inch wheels were an upgrade and the 16 inch wheels were the normal stock size
here is something to think about:
http://www.roverparts.com/Parts/STC8486G.cfm
and
http://www.roverparts.com/Parts/STC50069G.cfm
both look the same (actually the exact same picture) however the D2 version is $20 more and they do not appear to be interchangeable, also the cloth style covers say loose fit on the D1 which would make me wonder, and finally the plastic cover that you are showing does not list as fitting on a D2 according to AB.
http://www.roverparts.com/Parts/BTR9438MUEG.cfm
Old Nov 18, 2009 | 04:11 PM
Thanks for the input. I found one exactly like the one that I posted for $20. It was originally for a 2002, but yeah, 02's have 16's and the 03's have 18's, so it probably won't work. Anyone know where to get one like the picture I posted that will fit an '03???
Old Nov 18, 2009 | 04:54 PM
Rover Curious's Avatar
I don't believe they made one that design that will fit an '03. The problem here is that a D1, which that was made to fit, had a steel spare which was recessed from the sidewall of the tire, so that cover sat down in the wheel, flush with the tire. All D2's have matching alloy spares, especially an '03 SE like yours and mine that have the 18" Hurricanes. I too really like that center cap, but it won't work.
Old Nov 18, 2009 | 06:03 PM
Bummer.
Old Nov 18, 2009 | 07:03 PM
00&04 Disco's Avatar
Get one that looks like this.
Old Nov 18, 2009 | 08:28 PM
All DI's came with 16" rims.
DII's came with both 16" and 18" rims, depending on the trim level.
That spare wheel cover will not fit a DII 16" rim because the bolt pattern is different from the DI to the DII.
I have one of those spare wheel covers in my garage.
wrongway1
Oct 20, 2013 03:24 PM
Madlands
Dec 11, 2012 10:19 PM
ScreamingLife
Oct 9, 2012 05:56 PM
Frank4
Feb 24, 2011 04:57 PM
instg8r
May 17, 2010 07:38 PM
