will straight ant-freeze hurt anything?
Old Jan 2, 2012 | 10:01 AM
  #21
94svt50's Avatar
Thanks for the replys! Looks like mine is going to take right at 3 gallons.
Old Jan 2, 2012 | 03:26 PM
  #22
SolbergFanBoi's Avatar
A 50/50 mix isn't necessary unless you are in an extremely cold environment... Here in the SF Bay Area, we don't see anything below 30 degrees on the coldest nights of the year, mid 40's at the absolute coldest during the day, running 50/50 is overkill if you live in an area without extreme temps.
You will have better heat transfer, lower coolant temps with more water in the system like a 60/40 or a 70/30 mix. You do sacrifice water pump lube and corrosion protection but Water Wetter or Purple Ice will help with that. Just some useful information
Old Jan 3, 2012 | 07:30 AM
  #23
antichrist's Avatar
I'm pretty sure the 1st number is antifreeze, so 70/30 would be 70% antifreeze.
Keep in mind that the higher concentrations also raise the boiling point of your coolant.
Old Jan 4, 2012 | 12:18 PM
  #24
I said more water so 30/70 mix...
grandkodiak
May 10, 2012 08:38 AM
georgep
Oct 12, 2010 10:41 AM
georgep
Oct 1, 2010 07:00 AM
sopjih
Oct 2, 2006 04:43 PM
MEP
Nov 29, 2005 12:22 PM
