Window
My passenger rear door window was doing the same thing, and if i hosed it off to wash it it got a little water inside, looking close i noticed that the felt seal on the vertical rail of the window had slid down the track leaving about a 1/2" gap at the top. I just rolled the window down a bit and pulled it back up. Haven't had a problem since.
I had the same thing on the front driver's side window ... I read a post that said to lower the window all the way and then put a knee on the top of the door panel and pull a few times at the noisy corner of the door frame. I tugged three times but not very hard. I took it for a test drive and noise was gone. I'm sure there is a more appropriate way to do this but hey it worked!
twoxred
10-04-2021 07:07 AM
phillman98
12-04-2010 10:01 PM
Dan_da_LR3_H2_man
06-03-2009 04:05 PM
