Window
Old Jan 14, 2008 | 11:10 AM
ccvalentino's Avatar
Default Window
I have a 2000 Discovery Series II and have what amounts to a wind tunnel / draft coming from the driver's side passenger window. The rubber seal is in good shape and shows no dry rot. Is there any way to adjust the door?
Thanks,
Chris
Old Jan 14, 2008 | 01:11 PM
zerochills's Avatar
Default RE: Window
do a search, there was a post within the past month in regards to similar issue on drivers door though.
Old Jan 14, 2008 | 06:29 PM
tailchaser0527's Avatar
Default RE: Window
My passenger rear door window was doing the same thing, and if i hosed it off to wash it it got a little water inside, looking close i noticed that the felt seal on the vertical rail of the window had slid down the track leaving about a 1/2" gap at the top. I just rolled the window down a bit and pulled it back up. Haven't had a problem since.
Old Jan 14, 2008 | 10:06 PM
afphinfan's Avatar
Default RE: Window
I had the same thing on the front driver's side window ... I read a post that said to lower the window all the way and then put a knee on the top of the door panel and pull a few times at the noisy corner of the door frame. I tugged three times but not very hard. I took it for a test drive and noise was gone. I'm sure there is a more appropriate way to do this but hey it worked!
twoxred
Oct 4, 2021 07:07 AM
RedAustinIX
Aug 10, 2020 11:43 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
