Window motor replacement help!
Old Aug 13, 2015 | 07:13 AM
russburcham's Avatar
Default Window motor replacement help!
Good morning crew- purchased a new rear passenger window motor the other day, grabbed the rave and set out to replace (stuck in the down position) BUT the bolts holding the glass aren't "lined" up to remove them- I tried a little elbow grease to get them into position to be able to see them, but to no avail.
Has anyone dealt with this before or have any tips? Thanks much!!!
PS: it's been VERY rainy, floody, soggy here in Tampa lately, so a hasty resolution is needed! Haha
Old Aug 13, 2015 | 06:59 PM
nobody's had this issue? the window wont seem to budge up or down to get the screws into view for removal of the window glass
Old Aug 13, 2015 | 07:21 PM
Charlie_V's Avatar
I have.
You have to completely unbolt the assembly and lower it until you spy the screws/bolts/nuts (I can't remember which) that hold the window on the track then remove them while you hold it in place.
Old Aug 14, 2015 | 05:48 AM
Thanks Charlie!
RedAustinIX
Aug 10, 2020 11:43 PM
Al Blue4.6l
Aug 14, 2011 05:28 PM
jayandy
May 15, 2009 06:13 PM
calebmorphew
Dec 11, 2008 09:40 PM
