Window regulator issue....need advise
Old 01-08-2019, 06:38 PM
GCBurke's Avatar
Originally Posted by stb616
Where did you order the regulator?
I ordered from britparts on Amazon....$33 and since I have prime shipping was free.
Old 01-09-2019, 09:21 PM
garrddogg's Avatar
I have done regulators twice in the last two weeks. (different ones) both had died wile in the "UP" position, there are four screws to that you remove and two that remain and are keyed in the door, I removed all four and the regulator lowered to the bottom of the door at that point I was able to access the two bolts that hold the window to the regulator at that point I used masking tape to hold the window in place. one was the FR regulator and the other RR was the window motor, but I also found the regulator was binding a little too. If its stuck in the raised position the key is to remove all four screws.
GCBurke (01-11-2019)
Old 01-09-2019, 10:55 PM
ReconDoc83's Avatar
I just did a thread on the driver side regulator replacement and the optimal solution. First remove all four of the regulator frame bolts; then begin to ease the entire regulator to the bottom; stopping long enough to disconnect the motor wiring harness as it passes the little round hole. Then remove the two bolts that hold the window to the regulator frame. Once the window has been released from the frame lift the window back to the top and hold it in place with a couple of screwdriver handles; then you can freely manipulate the regulator in the bottom of the door.
doc
GCBurke (01-20-2019)
Old 01-11-2019, 01:38 AM
shanechevelle's Avatar
For $40 I can buy the whole door with all the insides at the upullit.
Old 01-20-2019, 05:37 PM
GCBurke's Avatar
Just came back to say ....removing all the bolts and unplugging the motor allowed me to drop the window down and then pull it down far enough to remove the bolts holding the window. The rest was a straight forward replacement of the regulator.
Old 01-28-2019, 09:01 PM
garrddogg's Avatar
YES! You'll be doing it again soon too.
OffroadFrance
08-09-2014 12:03 PM
NabisOne
09-04-2013 12:20 PM
workinghard1713
06-21-2013 01:21 PM
dcreekmore44
05-07-2009 02:21 PM
Roveroh
02-10-2009 12:04 PM
Quick Reply: Window regulator issue....need advise
