window switch drama.
Old Nov 14, 2007 | 08:23 PM
indys2k's Avatar
Default window switch drama.
I did a search and located a few different anwsers, maybe you guys can tell me the solution that works most often. Heres my situation. I have a 98 Disco I LSE, the rear windows will not go down or up with either the center console switches or the rear door switches. My heated seats buttons do work along with the front window switches in the console. Does this sound like it would be the sodder connections in the window ecm under the glove box?
-Tyler
Old Nov 14, 2007 | 09:21 PM
okdiscoguy's Avatar
Default RE: window switch drama.
that's what I was going to say. YOu could pull your switches and clean them first, just to try. I think there is a good write up on this on discoweb.org under the tech tab...
Old Nov 15, 2007 | 08:43 AM
You hit it right, it is the body ECU, most likely a cracked circuit board or a bad solder, both of which can be fix or you can go buy a good guaranteed used one from,
http://www.roverlandparts.com/index....S&Category=450
Old Nov 15, 2007 | 08:46 AM
indys2k's Avatar
great, ill tackle this issue this weekend and let you know how re-soldering it does. Thanks for the link Mike, ill use that as a last resort if my soldering fails.
abran
Aug 5, 2014 06:13 PM
AZRover
Jul 2, 2012 06:43 PM
phillman98
Dec 4, 2010 10:01 PM
ghostrider747
Oct 23, 2008 06:00 AM
miishmiish
Feb 26, 2006 07:20 PM
